@saforwardlook There is a right way to do it, prime the oil pump. Everything else is wrong, and has potential to damage parts. Many engine start up articles in the past would say “No excessive cranking, make sure it is ready to start.”
My reply was short and to the point. All the details can and did come later. I’m trying to get this silly idea of cranking to get oil pressure OUT of your heads and these threads. It’s a foolish idea that doesn’t help anything. if priming the oil pump is too hard (daunting) then find another hobby. It takes 10 minutes.
@Isaiah Estrada is a go getter and he can do this. I’ve read his articles and he is more than capable of following instructions and not afraid of hard work! I commend his attitude and efforts on his 68.
You’ve spent at minimun $3500 if you have done most of it yourself, or $6-$8000 if you had a shop do it all to get this new engine in the car, don’t cut corners now.
This is a new engine with tight clearances and valve spring pressure on the cam lobes. You don’t want to start cranking it to get oil pressure. Do everything possible to ensure it all lives without damaging things. Cranking the engine is the time when damage occurs.
Prime the oil pump with a drill and oil will be in every bearing, now rotate the engine twice with a breaker bar and oil will be in every rocker arms and both rocker shafts. Ready to start
