I see from a previous post that you repaired the dash light dimmer switch and that got your lights back on, correct? If that is the case I would pull the switch panel back out (unless you can see the switches from underneath the dash) and see if something came loose. The rheostat coil, or something touching it. If all looks good start looking at your orange wires. Those are all controlled by the dimmer. Touching ground somewhere? Wrong bulb in any of them? Was anything changed or repaired after the dash lights worked?
