SF-66TC
Ok Gents! Found a crack that went straight across the timing gear so while I have everything apart I might as well detail the engine compartment as much as I can.
'66 Town and Country (67K miles) that came with a 2-bbl 383 that pops converted over to a carter 4-bbl. Engine was rebuilt back in the 70's due to I think, a spun bearing. When pops
put the engine back together he just spray painted everything with whatever paint color he got from work which amounted to; silver, gold and black. What I'd like to do is return everything back to its original color and that includes any associated brackets etc. I only know as much (mostly from others photos) that the intake manifold, valve covers, heads, block, water pump, timing cover and oil pan cover were all painted the Mopar Turquoise, BUT what about anything else?
From current photos I do see that a couple of brackets (air conditioner and accelerator linkage/brackets) are painted the Turquoise color... I'd like to try to get as accurate as possible so if anyone has any photos or input that would be most helpful. Thanks!
