1- Sounds like a classic stuck open T-stat...
Not saying you are wrong but wouldn't it want to overheat with a stuck open t-stat? it never ever get's above 195
No, it would not want to over heat with it stuck open. Think about the hot water tank in your house. If the flow of water never stops or slows through it there is no chance for the water to get hot.
The thermostat being closed is the only thing that keeps the water from circulating from the engine to the radiator to be cooled. If the thermostat is stuck open the water pump keeps pushing the coolant from the block into the radiator. When operating correctly the thermostat stays closed until the coolant reaches the temperature it is designed to open at (160, 180, 195). Then it opens and the coolant flows to the radiator. This causes the coolant to decrease in temperature closing the thermostat again until it reaches the temperature that it opens at. If you drive for long enough, say an hour, the temperature of all of the coolant will come up to temperature and the thermostat will stay open all of the time.
I hope this helps and wasn't insulting.
Answer to both of your posts... sometimes, yes, if the opening is less than full flow. Otherwise the restriction of your thermostat opening is meant to be your maximum coolant flow... sometimes when we need to get one back running right away or for diagnostic purposes we may cut the center out of the old thermostat and reuse the plate... the circle track boys like these:Not saying you are wrong but wouldn't it want to overheat with a stuck open t-stat? it never ever get's above 195
I was just going to say JP was probably on the money with the low coolant, with the air going the the highest point in the system. Not sure with the durango's but you need to be in the right mood to change the stat on the rams - not as straight forward as the older cars![]()
Kinda the same w/a 3.3. I should probably do mine, but you know the sayin about if it isn't broke thing cause I'm sure something would get dicked up.
Just want to make a suggestion here... because you are going to a shop for this anyhow, please let them do the diagnostic. It was the bane of my existence when a customer came in with the idea that I would actually repair whatever they said to do.Update - had pretty frosted windows a few days ago and after about 10-15 min or so the windshield was mostly frost free ... basically in the wiper path was frost free and upper part had soft slush - I didn't have the wipers on, just a description of where the defroster had melted the frost. Also it's heats up normally now to operating temp at idle.
So whatever the issue was I'm glad I finally had it dealt with !
I now have another vehicle (2002 V6 Mercury Sable) with no trouble heating up to operating temp (coolant is full) but the heater will not put out much heat - at best its basically not cold but also not hot air. I'll probably be taking it in for a cooling system flush and a back flush of the heater core and a new thermostat. Lots of crap came out of the Durango's heater core when it was back flushed.
I've never had heater problems with vehicles before ... when I was driving older vehicles that is.
i had an 02 taurus with the same symptoms. in my case there were metal tubes along the rear of the motor that connected to the heater core. the tubes rusted internally and plugged the core. new tubes and a reverse flush of the core and all was well.
a word of caution if you change the tubes yourself, you WILL rip your hands to shreds on all of the pins and bolts sticking out of the firewall.
The new stat solved your problem by staying closed making the coolant stay in the engine until it came to temp. Then it opens allowing cooant to flow through the rad. Then cool water hits the stat and it closes.
My 92 Dakota had the same problem. Changed the stat and it didnt help. Changed it with a Stant brand and it works.
Tauruses and Sables are well known for clogged heater cores. Got one of those, too.
