Dome lamp part 2, 69 Polara
polarnj
NJ
My dome lamp is the type with a switch on the front. It seems to pull a little shade back and forth to light up the front or back seat, is that also an electric switch as well?
Seems that in the forward most position the light is off. Also the lens keeps falling down but with the switch all the way forward it seems to hold it up tightly (?)
Probably has some of the locking tabs broken or disintegrated with age. It just snaps into the base.
The switch works just like the map light on the instrument panel. It can come on as a normal dome lamp when a door is opened, or it can be turned on with the switch, other than the light switch on the instrument panel, as desired.
How do you set it to open with the doors? I've been able to get it on and off but not with the front doors (was working until I changed the bulb )
Expensive dome lamp as it was used in the 70/71 E body cars.
The switched style ones are found in the Barracuda Gran Coupe and Challenger SE
Yes. If your little door switches are busted/unplugged they won't trigger the domelight to come on with the doors.
Basically all the way forward is full dome. Then with the switch back it should shield the light and force it through the little slot to put a narrow beam of light right into the front seat. Dome/map light.
