Dual belt alternator pulley set up
carrman
Medford, OR
Guys, I'm currently running a single belt for my alternator on the 440 in my '68 Newport with power steering but without a/c. My electric cooling fan(Mercedes) draws enough current to cause the alternator belt to squeal loudly in protest. Belts adjusted correctly, but I know I need to go to a dual belt alternator. What pulleys besides the alternator do I need to obtain to do this?
What type of belt are you using?
Reason I ask is that on the later 1970s Cadillacs with the factory 100amp alternator, the pulley was smaller than normal AND used a toothed/cog V-belt to run it. The "teeth" allowed the belt to better get around the smaller diameter pulley. Usually seen on cars with the electric rear window defogger.
that's what I'm running.
