70bigblockdodge
So the RPMs are just better cast standard ports and bigger valves than a 906/452 iron head? Not his he has 1.60 exhaust.Not to raise a ruckus here but high performance heads and engines are my business. The RPMs are a standard port head as are the Victors unless you order the Max Wedge Victors. The ports won't be too big in volume but I fear the valves may be very close to the cylinder walls of a 361.
Smart *** question
Who is not ordering Victors without max wedge ports? I'm sure there is a reason just not a good reason.
I like when you get sucked into these threads and clean up the mid information Thank you
