My 65 New Yorker was converted to electronic ignition by the previous owner. The problem is he wired a toggle switch to the ignition to supply 12v when cranking. I would prefer to not have a toggle switch but I can't find a wire that has 12v at both cranking and run positions. Everything I find is either hot cranking or run, not both. What is the trick here? My distributor is a 2 wire with an internal module.
Thanks!
Thanks!
