70bigblockdodge
I wonder if that little plastic tube from acc pump to discharge nozzle isn't leaking.
After 40 years and ethanol gas.
I've experienced this a few times. Might not be the same for your car, but it sounds to me like there is a small vacuum leak. Check the valve on your Power Brake booster, also look at all the hoses coming off the intake. A slight leak will cause the stumbling you are mentioning.
Peter, if you Mechanic is worth even a fraction of what you pay him... by all means print the thread and give it to him, but please allow him to diagnose the issues. No self respecting Mechanic will want to follow the Internet's directions to do his job, but no wise one would ignore a little good advice so long as it didn't cut into his time too much.Wow, all this great advice. I am in Conakry Guinea now, and the Newport is in a garage.
In three weeks or so, I will have it driven to my mechanic and:
Ask that we check again for vacuum leaks, paying special attention to all the tips you guys have given;
Failing improvement, replace the TQ with an eddy 1406 reman
Look for a place to buy non ethanol gas (not sure where to find that in DC)
Not sure how much work is involved in pulling the intake. Perhaps best done when replacing the carb?
I will give my mechanic a printed out version of this chain and ask that he read it.
I go back for some R&R second week of March and will look forward to an empty wallet but also a smooth running Newport.
Thanks
Peter
The tips given shouldn't be needed. A real mechanic would have done all of the tips given already.Ask that we check again for vacuum leaks, paying special attention to all the tips you guys have given;
And bring it to Carlisle...This has got to be the luckiest Newport in existence. I have poured thousands into it. Many faults have been fixed. I am determined, no driven, to have it run well.
So we are finally now about to put in the eldebrock. Most folks here have recommended a 1406. But my mechanic says that runs even leaner than the TQ it would replace. He was thinking about the 1405. What do you guys say? Plus he says the 1405 comes with an electronic choke.And bring it to Carlisle...
I have had nothing but problems with my ignition system and carb. No doubt due to some problems that came with the car, mistakes made by my mechanics and/or bad parts that we have put in. Or some evil combination.
About 6 months ago, we removed the lean burn. Everything worked well for a couple of months, but then the ignition began cutting off at random times. We diagnosed that as a faulty orange box (ICM). Put in a ICM made by standard and that stopped producing spark after a couple of weeks. Completely. Now we have put in a chrome ICM made by Mopar. That problem seems to be solved, and the spark is strong. Starting is either instantaneous (just after shutting down) or after just a bit of cranking when cold. I can live with it. The choke works well.
But the engine runs a bit rough at idle, especially when warm. Barely noticeable, but it is there sometimes (and sometimes not when the engine is cold). Feels like a very tiny rumble/misfire. And the engine stumbles and bogs just a little bit when you accelerate very gently from idle or a stopped position (on the flat). Or when you go up a hill, very slowly, from a stop. As you speed up past 10-20 MPH or so, the engine smoothes out and runs perfectly. At highway speeds, she runs like a champ. Smooth.
To fix this, we have rebuilt the TQ (original) carb. Twice. We have replaced the spark plugs. We have installed a new ICM. We have checked and adjusted the distributor. We have readjusted the choke and the vacuum advance. All wires and connections have been checked. Everything has been gone over twice. I'm sure I am missing some stuff.
You guys know by now that I am not a mechanic. But I choose my mechanics carefully, and the guy I have is good. But he seems to be stumped. And like all of us, he isn't perfect. The latest theory was that we replace the spark plug wires.
Any ideas? Thanks as usual!
Peter
