Fratzog
Had a similar problem about 12 years ago on a long trip. Had to keep filing the points to limp home. Installed new points and condenser and life has been good since then.
If it is still on points, they should be changed. If they are not set properly and in good shape the coil will not saturate enough to create a hot enough spark to handle load/rpm.
That's where I would start.
No more hesitating, stumbling or whatever when revving up..The 383 in my vert does the same thing so I run it without the advance.
No points on mine, the distributor just must be weighted right for the engine to not require any vacuum advance.Maybe time for changing points ??![]()
You just need to tighten the spring in the vacuum advance canister. It will get better MPG and make those new rings last longer.No points on mine, the distributor just must be weighted right for the engine to not require any vacuum advance.
