- Joined
- Nov 14, 2010
- Messages
- 28,571
- Reaction score
- 28,456
With all the rain this could be somewhere in the Carolina's
You were at Barksdale? This happened before I got there in 89This happened 31 years ago today, lost one Airman the was way in the back. I was on base when this happened.
What was the cause of the accident?This happened 31 years ago today, lost one Airman the was way in the back. I was on base when this happened.
-- On Sept. 17, 1987, a KC-10 exploded at Barksdale Air Force Base in Louisiana. Again, the cause was attributed to a fuel vapor explosion in the center fuel tank. One mechanic died.
Investigators found that fuel had leaked, and vapors probably had been ignited by arcing from a battery near the pump area for the tank.
Shortly after the incident, the Air Force ordered checks of all KC-10s and found a dozen similar leaks.
I took this from a article I found
Mack's only have double frame from the rear up to the back of the cab. Not a uncommon problem with Mack tri-axels. Usually happens with the body up, one side will collapse.
