The tire is supposed to pop on to the bead, obviously it didn't work for that guy.? Wha?
Ah. I get it .. in theory. I wouldn't have the balls to try it though. If a ratchet strap and high pressure air doesn't work, off to the tire shop it goes.The tire is supposed to pop on to the bead, obviously it didn't work for that guy.
Guy's usually use ether or something similar that burns fast and creates a small explosion to push out the tire to seat the bead. It looked like he was trying to use diesel fuel, I am judging that by the blue fuel container.The tire is supposed to pop on to the bead, obviously it didn't work for that guy.
Some things a tire shop won’t even attempt.Ah. I get it .. in theory. I wouldn't have the balls to try it though. If a ratchet strap and high pressure air doesn't work, off to the tire shop it goes.
Pumped ether into the cylinderswhat did that unmarked button do?
You have to use way more now because it is so crappy, then you get the whooosh, boom if a little bit too much.We did use Diethyl Ether starter fluid in a spray can. Little squirt in the tire and throw a match at it for an instant bead set
