Yes, thank you very much for posting that. Once I get the intake manifold buttoned up and hopefully resolve the rough idle I am going to try and read through this thoroughly before doing anything else electrical. Great info for sure.
Also, check all of your grounds (eng to frame, frame to body, eng to body). Had a similar problem with my '86 Ford wagon. I added a ground wire from the body to the block, and the problem went away.
Thank you to evryone that has posted about my problem
i have a lot of checking to do
first i will add a ground from eng to frrame (that is missing)
19newport67
