65MonacoND
I would say the repop was just slightly thinner than your thinnest one of the originals.
As promised, I grabbed a couple pics.
So... Here's what is interesting... These are both factory pieces, but out of different cars. Note the difference in thickness.
The thin one came out of my car, 70 300 'vert. It may or may not be an original piece to the car. I have no way of knowing. It is a factory piece though.
Thinking about it, the repop could be done in the same thickness, but the compromise would be to not stitch completely through. You could stitch to a thinner, shaped backing, laminate to a thicker material and then wrap vinyl around the back and glue in place. If done right, the handle would look "correct" from all angles except from the backside and that you would not be able to see once on the car.
