Fuel Tank Gauge Unit Grounding
wihaltom
Baytown, TX
I know this has been discussed in some other threads but I can't find what I'm looking for in any of the threads.
I am trying to get my fuel gauge to work.
It registers between 3/4 and 1/4 from full to about 1/3 tank.
I got under the car and looked at the sending unit.
There is no ground wire for the sending unit.
Only the wire to the gauge.
How does the sending unit get its ground?
Is there supposed to be a ground strap that bypasses the rubber fuel line connected from the sender to the fuel line?
Is the tank itself supposed to be grounded to the frame or something else?
I am thinking the problem is a ground problem but I don't see where the ground comes from.
My GM and Ford cars all have a ground wire attached to the senders and grounds to the frame.
Thanks for whatever help you can provide.
Weldon.
That's the way it is on my '78 Newport, but when disconnected the gauge doesn't work at all. (stays on empty.)
I added a ground wire from the fuel line from the sender to the frame.
Same result.
The gauge does go to past Full when grounded.
I'll keep chuggin' at it.
This is what you need. Most mopar suppliers will have them.
sounds like a bad sending unit
X2 I think it is a bad sending unit too. I forgot to install the clip above on my new sending unit and it still worked perfectly. Sending units seem to loose their calibration over time or in some cases never right from the get go. I got a new one from auto zone I believe. This was debated with me over rebuild old buy new. I went with new form the good responds from other members. I couldn't be happier it is the most accurate sending unit I have. On the E line it has 5 gallons 1/4-10 gallons, 1/2-15 gallons.... It can be done in place it is a pretty easy job if it is on a lift, but I imagine the old one is stuck in there pretty good.
If the gauge is regestering then it is getting a signal and a ground.
Could very well be a float issue.
You will have to remove the sender unit to check/service it. If the sender looks ok just change the float, otherwise change the unit. At the least you will need a new gasket to reinstall it.
Sorry, Dramamine was still working on my brain from a 22 hour bus ride back from performing in Disney.
Correction: If the sending unit is not grounded I am pretty sure you should be reading completely empty
What is the range of ohmic values from full to empty?
On my 64 El Camino, it is 0-30 ohms = empty to full.
Same thing for the new sender in the 67 Cougar.
The sending unit that is installed is a relatively new one.
It was installed with a new tank in 2005.
That being said, that doesn't mean it works correctly.
Are there different senders with different ohm readings or are they all the same except for the line size ( 5/16 or 3/8 line)?
I wonder why gas gauges give so much trouble.
I have three old cars (and going this afternoon to look at a 65 Chevelle SS) and they all have or had a problem with the gas gauges.
I think it may have to do with the reformulated gasolines we are forced to use now.
Lots more corrosion in the fuel systems than before.
My sending unit is actually fine - and I replaced the instrument panel. All that really leaves is the line from the tank to the gauge.
Because people are too damn cheap. Years ago I remember dropping tanks constantly. Now? Two things people never fix. Fuel guages and A/C. But they have to have the pimp wheels and da stereo.
< Sent from my tablet >
