BJS racing
The power to the regulator will be a blue wire that is also the same power source that would be power to the ballast resistor. Here is a diagram of both the early mechanical and late electronic charging systems. The field wire is usually green.
![mopar charging systems 2.jpg mopar charging systems 2.jpg](https://www.forcbodiesonly.com/mopar-forum/data/attachments/23/23294-4f993f6c11488a818e07656b431c2cc8.jpg)
The alt ign terminal on the fuse block is for the ignition hot power for the regulator. This would be a white wire on the fuse block.
