Northcoast300h
What happens if I cap the one vent leaking and use a vented gas cap? (Currently I have a non-vented cap) Will that work?
Bought 1970 300 Hurst without fuel tank and installed a 1972 Newport gas tank. Runs good, nothing leaks when driving. Only happens when gas tank is more than 1/2 full. After approx 1 minute of it being parked, I hear gas tank percolating like a coffee pot and fuel comes out of one of the vents for about 10 seconds. It makes approx 6" round puddle. When percolating happens, I removed non-vented cap but no difference, no vacuum sound.
Maybe I put them on wrong? Circled is the vent where the gas bubbles out. Square is the 2nd vent that goes into the trunk and comes back out under car but I couldn't see exactly where. Looks like it comes out above the exhaust but doesn't leak. 3rd line is fuel to carb. 4th is return vapor line from carb to fuel tank. (pretty sure its only vapor going thru this line from carb)
Ignore loose cheap chinese stripped clamp. There's another one on there.
Thanks for any help.
