Looks like someone has been in here before to try and fix the problem...probably the former owner as he told me he checked and made sure the ground was good.
Thanks, Bob
no smoking, no sparks. no pilot lights. unhook the battery. be outside. you are gonna have some fumes.
Where would I get one of these? If I can't get one, would a generic grounding strap with a couple of tiny hose clamps work?The factory ground strap almost always works better and looks like this:
Thanks John...actually I just did a search on e-bay and found the grounding strap. "For Cuda and Roadrunner" but states it fits 1968 Fury too. You've also answered my next question...if in fact I need a new sending unit.
Additional question: What's the deal with the other 2 tubes on the right in the photos I posted...I take it they're the vents?...but they run up into the trunk where they meet each other. In other words they're the same tube. How is that a vent?
Thanks so much...
Bob
You know...now that you mention it, I have to agree with you...but those rubber connections look to be fairly new. I'll check them while I'm working on everything back there. I pulled the sender yesterday. The connection inside came off rivet which holds it to the wire sender stud....plus the brass float is taking on gas. I'm working on repairing it...initial testing confirms I've fixed the broken wire as gauge now works as I raise and lower float...Several attempts at soldering holes up on float not going well though. I'm testing my solder patches but float is still taking on (water now) as I'm submerging in a container filled with water in kitchen sink. (I have a very patient wife)Sounds like you got a handle on the sender, I would change the vent hoses though, looks like they are leaking judging by the stains and what looks like a wet spot.
Bob
