What is your car/engine?
I wouldn't give up on the TQ, if it is the correct one for the car it is calibrated for the engine. Some Eddy carbs are calibrated rich, some lean (you must research the specs to know) and unless you get a WB o2 gauge and a calibration kit, and spend lots of time fiddling with it and watching your MPG in-between, simply 'putting an Eddy on' is shooting blind at mpg vs the TQ. If the car is running smooth leave the TQ alone, it's one of the best-MPG carbs Chrysler ever used (it has a bad reputation due to the plastic fuel bowls, lack of tunability for performance, and non-knowledgable people 'tuning' them).
I have read that LB units suffer issues due to a poor ground path, they ground thru the aircleaner stud and nut. Reportedly adding a separate ground wire helps with intermittent problems.
Most people want to simply find some solitary magic 'fix' that they've overlooked, and then see MPG go up and stay up regardless of all else. Tuning for MPG must be approached scientifically, and methodically, and the resulting changes must be monitored carefully. IMHO most people do not realize what is involved, you can make a change and think you gained soemthign, but there's usually another variable in there also that you don't see. If you don't sort out those variables scientifically (fuel quality, headwind, road speed, and bunches others) it takes forever to figure out a trend, and by that time on an old non-EFI car something else is out of tune and the situation changes anyway. Or 'winter gas' comes in...
But here's a magic fix -
Speed is a huge reducer of MPG. Drop your highway speeds down and your mpg *will* go up.
