Gas puddle from tank vent line
the cap should be vented. non-vented caps are for emissions vehicles with vapor canisters. mine is marked "vented" "anti surge" and is oem. other thing to check is o-ring sealing the sender.
Sounds like some clarification is needed.
1. Knebel, is your filler behind the rear license plate?
2. rags, are you using your '65 300 as a reference? If so, where is the filler?
3. If the tank and cap are vented, and the filler is behind the license plate, fuel will slosh rearward on acceleration and spill out through the vented cap.
4. My FSM is at the shop, but it specifically states that the vent lines must be kept open/clear. Otherwise the fuel tank will collapse due to airlock as it drains. This reasoning pretty much dictates that the cap is not vented.
5. All of my '67 Newports have non vented caps. None of them are "emissions cars with vapor canisters". None of them leak fuel anywhere unless something is compromised. No matter what fill up/top off technique is used.
Hope the input helps.
John
'65 300 is behind fuel door above plate. '69 is behind plate, but oe cap is long gone so can't vouch for it. cap currently on '69 has "caution open slowly"! have to admit, i'm with the $6 club above.
relevant issue is that it's not oe. might have come from anything. was the first under the bench cap that fit.
Now I need clarification.
John
Yes, filler on the back behind the license plate. Well, it drives me nuts too, and I dont like that everyone puts that metal filler cap on the trunk instead on the floor next to them. Gotta put a steel wire on it or so that it can hang loose. Man, when I get gas, most of the employees can barely remember the grade of fuel and the amou t of money i am asking. Now adding the "stop at 1st click" might be challanging.
Old thread, but...
My 68 Fury never leaks from a vent tube, actually none of mine ever did. So I disagree that it's normal. Modern EFI-era fuels are designed to evaporate more easily, but again, none of mine leaked from vents at fillup.
I would say a vent tube is blocked slightly, the non-vented cap allows pressure to build, and it 'pops' thru the vent tube. And those vent tubes aren't just a fitting, they run thru the tank, usually to opposite end of the tank to prevent slosh from traveling full-length.
Easiest solution is to not fill it up as much, but further investigation/repair is a more solid/complete response to teh situation.
My car always seems to spit fuel back at me while filling up. Usually around 10 or 12 gallons it does this, then I have to just barely pull the trigger and let it trickle in til I can't stand it any longer and give up around 16 gallons...and now the damn thing isnt even reading correct on the gauge again. Reads about 1/4 when it should say 1/2. New sending unit was installed earlier this year too. But I dont feel like fighting that crap again, maybe next spring...
I have a tank collapsing issue. Vented cap (as original) and behind the plate. The vented cap is to let fumes out, but it doesn't let anything in. When it gets down to half tank, under constant driving, the tank collapses a little upwards, and I get a loud bangin' sound when going around corners or accelerating (as the weight of fuel sloshing affects the areas collapsing). So I figure it must be a vent line blocked somewhere? I got 4 lines coming out the tank. I need a new tank (rust), and sender (gauge not working well), which is on the to-do list, so will address it then. Vans Auto will be my source.
The only time I had fuel coming out the cap was when parked facing uphill on a hot day. The fumes expanded to the point the gas leaked past the gasket on the cap and dribbled out.
Yes, a tank collapsing like that is due to pressure not being able to equalize, and in your case I would agree due to blocked vents.
If your car is a 73, per your screen name, you won't have a vented cap like earlier cars. You will have a vapor separator and a charcoal canister under the hood with vent and purge lines to the carb. Everything has to work right.
This is all covered in your FSM. If you don't have a service manual, download a 73 Dodge Chassis Manual here: MyMopar - Mopar Forums & Information - Service Manuals
If you have a Plymouth or Chrysler, this will get you close enough until you find a FSM elsewhere.
