No reproductions for '65's. You have to either fix yours or get a good donor from a '65 Monaco, Polara, or Custom 880.
Is your fill pipe behind the license plate?would a'66 tank be interchangeable?
Then my money is on the fact that a 67/68 C-body tank should fit.It is. All '65 Monaco's, Polara, Custom 880's are. Not sure about wagons.
I have been told and confirmed by at least two people that the 67 tank works and the reason the mfgr doesn't list it as fitting earlier years is only because of the fuel line connections that were required by the CAFE rules.I am not saying that there is a tank out there that will or will not be an exact replacement, but I have never seen a repro tank say that it fits a '65, it is always '66 and up. '65's are a different animal on a whole bunch of different fronts.
It just so happens my car will be up in the air for a while so it's easy to measure.I'm thinking I should just bite the bullet and give it a shot,I've got to try something.
what year is that tank from?I think the tank I was looking at was 40.5x27.5x8It just so happens my car will be up in the air for a while so it's easy to measure.
If you get some dimensions, you can compare before you buy.
Notice how it is offset and snugs up to the frame rail on the driver's side
No I haven't taken out the tank,I'm still able to use the car as long as I don't put too much gas in the tank.We had it on the lift Friday to change the sending unit when we saw the area around the old sending unit was bad so we didn't want to disturb it until we got a new tank.On Monday I will get some measurements to compare.Joe do you have your tank out? If we had pics and you listed dimensions of it, that would help a lot.
the dimensions are the same :23 gal,40.5x27.5x8 the part # GT-VNK100 https://jimsautoparts.com/fuelpart.htm
And I'm saying that there is no later year tank that can be used on a 65 Fury because of the side filler pipe. This 65 Monaco has a rear filler pipe, like the 66+ tanks. I say the difference is in the vent lines which were different in the 65 and 66+ tanks.I am not saying that there is a tank out there that will or will not be an exact replacement, but I have never seen a repro tank say that it fits a '65, it is always '66 and up. '65's are a different animal on a whole bunch of different fronts.
