mr gtx
never seen a 915 or 516 heads that were 73 cc unless a lot of milling. they were 79-80 cc. the 1.60 will not hurt anything other than power in the upper rpms plus the 1.6 helps your torque in the lower rpmsHi Rip,
516 is closed chamber 73.5 cc. 1970 383 originally had open chamber 906 heads 88 cc.
I was also thinking about compression and wondering whether the transition to closed chamber would cause knock.
It's not my engine. I was talking to another guy. His 1970 383 has run fine with 516 heads for the first 5 or 6 runs with the car, but it didn't sound like he has tried wide open throttle. Also, with the smaller exhaust valves, I'm not sure whether that makes the problem worse with less cylinder evacuation at WOT.
Felpro head gasket may have added cc over the factory steel head gaskets, so that might have helped. I didn't ask what head gasket he used. Sounded like he had put the heads on without rebuilding them. Ben
