OK, boys and girls, you can indeed have a "numbers-matching" pre-'68 Mopar!!! Look at the scheduled build date on the fender tag. IF the casting date of the block, intake and heads, along with the build date of the carb are BEFORE that date, that is what qualifies as "numbers-matching"...YES, I know that there is no partial VIN stamped into the block or trans before '68. But that alone doesn't qualify a '68-newer car as "numbers-matchiing" if the other parts mentioned are not dated correctly, also!
