Crappy heads, 904 trans, 8.25 rear. It is a good disc brake donor.I would save it. It would take some time and money but, a 360 sunroof car? I'd be all over that pretty quickly.
ouch that was harsh but very true...sadly, mopars end for me at 73 beyond that i just dont really care.Crappy heads, 904 trans, 8.25 rear. It is a good disc brake donor.
Bolt on Magnum EQ heads or some alternative, door says it has 727, 8.25 is an okay rear axle and it has a sunroof. Of course I see something different I guess.
Man, you have just spent a ton of money on just the drive train when the rest of the car is bare worth it being a parts car.Rip it out put in a BB then you know you have a 727 and change the rear because it will not survive long behind a.BB with sticky tires. Sunroof just means weight and leaks, if you want wind and sun on your head stick it out the window.
