Hazard lights inoperative...
somewhereinthecity
Baltimore, MD
...although turn signals work fine. Guessing problem is the switch?
The issue is on my 73 T&C, which uses the same type of hazard switch as my 72 Dart and 73 Coronet.
Thanks,
Jeff in Baltimore
No idea -- never had a problem with a hazard light on any past vehicle I've owned, so never really explored. Figured someone here would know the definitive answer.
Yep, two different solenoids. Likely your hazard solenoid is toast.
Swap turn signal and 4 way flasher and see if the 4way flashers return. If you still have no 4 way oper. its time to get out the test light and a wire schematic covering turn signals and 4way flashers.
