Help find the Birthday
Shamu70
Illinois
I have no idea how to decode a VIN.
Can someone tell me when Shamu's birthday is?
I see the number 601 or 501...………...
So it is the first of may or june…...
MyMopar - Mopar Forums & Information - 1969-1974 Mopar Fender Tag Decoder
Tried to decode it, as best as I could read -- feel free to correct, of course, and pls let us know if that matches what you see on the car!
C: Chrysler
E: Economy
23: 2 Door Hardtop
L: 383 290HP 1-2BBL 8 CYL
0: 1970
C: Jefferson Avenue, MI, USA
245204: Sequence number
E61: 383 cid 2 barrel V8 290hp
D32: Heavy Duty Automatic Transmission
EW1: White Exterior Color
E2T5: Vinyl Bench Seat, Tan
FT6: Burnt Tan Poly Int. Door Frames
501: Build Date: May 01
291154: Order number
V1L: Full Vinyl Top, Champagne
H51: Air Conditioning with Heater
R13: Deluxe AM Radio (5 1/2 Watts)
L31: Hood/Fender Mounted Turn Signals
G11: Tinted Glass (all)
V5X: Body Side Stripes, Black
601 June 1st 1970 scheduled production date. Does the car have the VIN sticker in the drivers door jamb? What month is on there?
Yep, that looks to be correct. Though when I bought it a couple years ago, it had already been repainted; top removed. Stroker RB & 3.73 gears too. But the inside is what it was born with.
Thank you very much for taking the time!
Car is down the road in storage; had a great first time this year!
There is a lot of additional information on the build sheet. Usually under the driver side seat cushion or in the top half of the rear seat behind the springs. (2 most common places) Decode above appears correct.
@Shamu70 -- did you ever find a build sheet for CE23L0C245264 (or is it CE23L0C245204 )?
CE23L0C245294
Looks like a 9 to me.
Even though the schedule production date is for June first, the door mylar sticker might tell a different story. It most likely wasn't born in June, but shortly after June. It could be several moments later.
Let's see the mylar and the build sheet.
