SpaceWagon
Set of 3 Original Horn Mounting Spacers with the Correct Factory "flat washer head" Screws.
The plastic spacers are often broken or missing which causes the horn bar to be loose.
These were used for many years on Chrysler, Plymouth, Dodge and DeSoto models with horn ring, from 1951-1969.
Note: some earlier B-body and FL cars use 4 of the spacers to mount the horn ring. If you NEED 4, should be able to locate another one to make a complete set-up.
$15.00 Shipped
$15.00 Shipped
