I finally got the instrument panel out of my 1972 Newport. Many connectors are badly cracked. Fortunately, I found a place in Canada that restores MOPAR wiring harnesses.
Wow, what a job! Never completely removed a wiring harness before. Got it all disconnected from sockets in the cluster. One cable goes to the firewall into the engine compartment on the passenger side to whereabouts unknown. Do I just cut the wire bunch and install a connector for simplicity?
And how do I disconnect the harness power feeds from the fuse block? Do I remove the fused block from the engine compartment power source?
Another question: what are the round connectors called that plug into power buses? I can't seem to find this sort of connector, in order to stay original. The hot wires are always female so they won't short out if they touch the dash metal.
This project is much more complicated than I anticipated. I am labelling connections as best I can, but it will be a miracle to get the harness out, then reconnected once more when it comes back from rebuilding. One thing for sure: all the replacement bulbs will be LED so I never have to replace them!
