Newport 66
You can see the choke well etc mods.....
That's correct!View attachment 263227 So this is the only number for both of them?
Rinaldi Brothers in Mass. has re-pop balance tube hoses and clamps.yes, the ends of the hoses are different sizes. I do not know why, something to do with harmonics or pressure?BTW Newport 66, If your missing the block off plates . Jeff Carter of JCRestorations out in the Seattle area haz re-popped those with the two mounting bolt holes set correctly. You'll have band saw both endz and then final sand them I'd think on a wheel sander to custom fit them to your ramz but if you don't have them you'll be one step closer then you'd be without 'um. I don't know where to send you for the Balance Tube hoses? You do know that they're different diameter on each end to match the balance tube and the different diameter nipple on the ram castings rite? Only Mother Mopar would do such ah thing. And az far'z I know they're NS1 on the Entire Planet lol. Jer
Your Welcome. Passing information iz what makez the hobby work, IMHO. And Thank You for the Rinaldi Brothers information. I mentioned what I thought waz correct only because I bought the last 4 balance tube hoses I could find anywhere thru' my local Napa Dealer and he scoured the Napa Whole USA Dealer System to find me those 4 tubez. And that waz in '05. The 2nd set went with the Batwagon when I sold it in '13, JerAnd thanks for the tip on the plates!!!
