- 1972 Polara base model.
- I want to temporarily disable the seatbelt warning and key-in buzzers without disabling any other systems (lights, horn, etc.).
- I have the '72 FSM and BSM.
- The key-in buzzer wiring looks pretty straight forward. I assume I could remove the correct pin at the steering column connector.
- The seatbelt warning buzzer wiring is a mystery (to me). I found the relay right away on the wiring diagram for the Coronet. I tried comparing the wire numbers from Coronet to Polara. Nope.
- I disconnected the two-pin wiring connector under the front bench seat.
- I tried the "Search" forums.
- I want the ability to restore the systems if/when the vehicle is sold.
- Thanks in advance for your input.
