santts
Humming while diving my 65 Fury . Humming in rear . Diff fluid is up to level . I’m assuming bearings? 8 and 3/4 rear
Yeah that sway side to side is a good test but not 100%.
One time I worked on a guys car, we thought for sure the gears were toast, very noisy. Had a rusted up wheel bearing. Zero noise with one bearing replaced and other side
I’m hoping I can just repack and move on. I haven’t done back bearings since I’ve owned it . This is yr 4. I’ll keep ya posted .
I looked into it a little bit so far. What I noticed was who ever filled diff put to much gear oil. So I unthreaded plug and watched oil till it almost stopped . Put plug back and tested. Much quieter and no dampness near diff ( as their was prior). Due to overfill I believe. Still gonna suck out rest and put new and and motor craft friction additive .When I had my ‘65 Monaco I had a rear hum for years. It would go away when I made a turn or curve in one direction. Finally looked into it and it was a bad right rear axle bearing. Funny thing is after I had it replaced the car had way more jump off the line because it wasn’t hanging up anymore!
Just thinking about this.... If the oil level was too high, the oil could be up at the level of the axles. If that was so, there's a good chance of it getting past the axle seals and leaking onto the rear brakes. Possibly washing the grease out of the bearings too.I looked into it a little bit so far. What I noticed was who ever filled diff put to much gear oil. So I unthreaded plug and watched oil till it almost stopped . Put plug back and tested. Much quieter and no dampness near diff ( as their was prior). Due to overfill I believe. Still gonna suck out rest and put new and and motor craft friction additive .
