Bells Yorker
My 68 New Yorkers fan will blow the fuse when set to the highest speed, it will run all day at low and medium. I am assuming it is the resistor but i have read on here that when the resistor is bad the fan will ONLY run on high, so that is confusing. I have checked the wiring connectors and used contact cleaner on them.
Can I access the resistor through the glovebox or do i have to take out the dash?
Could the fan switch be the problem?
Thank you in advance.
