Texican6
He is talking about the "clips" on the under side of the upper trim that runs along the top of the fenders,doors,and quarters. The trim is a bear to get off without breaking at least some of them. No repos and as far as I know no NOS either. These clips were tack welded to the underside at the factory. If you have the clips a reputable shop should be able to "weld" them back on. If they are missing, you will have to track down used trim and remove the clips for your trim....unless the other trim is in better shape. There is also a small "V" shaped piece that attaches to these clips and it gets inserted into the holes on the body and then the trim gets pulled and locked in place. I have a box of these "V" shaped parts for my cars but have not seen any since about 6 years ago. Welcome to the world of "65 Monacos. Still tracking parts down for my 4 speed car and it ain't easy. Good luck.View attachment 36567
Thank you for the picture and suggestions. I have not looked on the inside of the trim so I am trying to decide from your picture of it is the same. I just talked with the painter and he is going to try to salvage these pieces and solder them back to the trim. If he cannot do that then he will probably have to try to glue the trim back in some way. It is not easy getting the clips out because they expand and 'V' out behind the sheet metal, kind of like a wall molly. We will see what happens.
