So, last weekend while I had the panel that lives under the steering wheel removed so I could install my tachometer, I thought I'd try installing one of my LED bulbs in the instrument cluster. I reached up to unscrew the nearest light socket, pulled it out, put the LED in, screwed the socket back in and turned on the dash lights to see what it looked like. Nothing. I thought the orientation might be off so I pulled it out, reversed it, plugged it back in, turned the dash lights on again. Still nothing. Perplexed, I put the original bulb back in and went back to installing the tach.
After getting the tach installed, I was ready to start the engine. Turned the key to "on" and noticed that the OIL light failed to light up. Turns out this is the bulb I had been swapping out. Started the engine, checked the tach, everything seemed in order except no OIL light with engine stopped and key ON. I went under the hood and checked for voltage at the sending unit to see if it was just a bad bulb. Then I was really perplexed because there was no voltage getting to the sending unit anymore. I posted a question on this forum, futzed around with the test light, couldn't find the correct wire at the bulkhead because a PO had painted absolutely everything with a thick coat of black paint. Decided it wasn't worth continuing on with at the moment, and mentally postponed the examination until summer.
THEN I noticed that my fuel gauge wasn't doing anything anymore either. It wasn't reading correctly before, but at least the needle moved. Now, the needle is pegged on E and doesn't budge no matter what.
Today I had the car up on a lift and I checked for voltage getting to the fuel tank sending unit - nothing. I cleaned off the ground strap real good, also wire brushed the metal fuel line and noticed that the sending unit looks to have been replaced in the last 5 years or so. Replaced the ground strap and checked again - still nothing coming to the tank.
SUMMARY - I changed out and replaced back to original the OIL light in the dash and now the OIL light doesn't work anymore and neither does my fuel gauge. No voltage is getting to either sending unit. What could I have done?
TIA
