mr. fix it
I'm not quite sure but I think the odour meter reads 32417 or 43417Tom, how many miles are on Betty?
The dash is quite dusty and not very clear
I can't get to it without disassembly to clean it
Will do here are a few from last year....Graham, post some pictures of the salvage yard if you get a chance during your next visit. Thanks.
it is higher than I replied withWow. That is very low mileage for a car so old.
Why power brake? Just size the master to not make it a bear to drive. His ratio on the pedal would be wrong and have to be changed to power brake pedal/linkage. Just make it manual disc with a two pot master, no stupid H switch no stand off valves, just a adjustable proportioning valve hidden down underneath the floor pans.(I'm not so sure I would do it just because you would have to go power brakes with the conversion
It's not like I would simply slap it together...Why power brake? Just size the master to not make it a bear to drive. His ratio on the pedal would be wrong and have to be changed to power brake pedal/linkage. Just make it manual disc with a two pot master, no stupid H switch no stand off valves, just a adjustable proportioning valve hidden down underneath the floor pans.
Damn Imperial drivers want everything loaded with power everything![]()
It was more aIt's not like I would simply slap it together...
It's not my first rodeo here boys...![]()
It was more a@cantflip for fun, I know it will be handled properly.
Slapping it together is more my cheap *** style.![]()
HeyDamn Imperial drivers want everything loaded with power everything![]()
I agree it is likely rolled over onceTrying to figure what the "1" on the body tag is for. Codes that end in "1" :
281 - 3 speed manual transmission
341 - Air Floam cushion on front seat
451 - Carpetting on floor (rubber carpets were standard on the Seneca)
461 - Sun visors - padded
Back up lights were code 372.
Might also be a "1" in front of the odometer reading. There is an awful lot of wear on the brake pedal for 30,000 or so miles.
Had an uncle with a 1965 Acadian Beaumont (Canadian Pontiac dealers' Chevelle) who put on over a 100,000 miles on it. Never in an accident and as he lived in a small community in rural Saskatachewan, his first stop sign after leaving his drive way was almost sixty miles later. He said it was a great car, although felt 90,000 miles was a little too soon to need a brake job.
If this Seneca saw life in a rural area it would not be surprising if it had over 100,000 miles. Kept out of the sun when not driven would keep the paint in good condition.
Had an uncle with a 1965 He said it was a great car, although felt 90,000 miles was a little too soon to need a brake job.
The more pictures you show of this gem, the more you really do suck...
The "s" is silentYou old sage you...
