Ignition cylinder removal / replacement 1971 Imperial
jet1969
Amsterdam
Could you please help me out how to get the old ignition cylinder out and a new one in for an imperial 1971. Is there somewhere a step by step methode or videoclip somewhere (youtube?) or a link to this topic? I was searching on this platform but could not find a thread. Thanks for helping me out
I think there is a special tool to hold the tilt/telescope springs from flying apart. Not sure if there is a work-around.
It sounds like you don’t have a service manual for your car either.
Yes I have the car service manual with steps to follow ( chapter 19-50) but it didn’t work very well. So that’s why I asked for suggestions, tricks, video clips, links to get a good result.
The tilt/telescopic column that Chrysler used was made by General Motors. This video of replacing the ignition cylinder on a 1975 Cadillac should be pretty close to what you need to know. This guy doesn't have a lock plate depressor tool, so he uses a little trick with the steering wheel puller to get around not having the special tool.
Jeff
Great , thanks for the video. Just managed to get the cylinder out, was completely stuck. Wd40 and all your help did it
