Indicators and Flashers
AJW300
UK
Hi all,
Just doing an all round check and have notice my indicators work fine, but when I put the flashers on the passenger side doesn't work, before I start going around and checking all my grounds, are there any relays/other bits that should be my first port of call?
Thanks in advance.
What year and model of vehicle are you dealing with? Do the brake lights work on both sides, via the brake pedal?
Just curious,
Just curious,
It's a 1970 Chrysler 300, the brake lights do work, I believe one bulb isnt working though
Yep, that sounds like a bad ground. A length of wire to a known good ground (like the battery) and touch the other end to the housings and bulb sockets. I'd change any bad bulbs first.
With my '70 300, I soldered a ground wire to all the rear bulb sockets which was overkill.
