I've just finished installing UCA, LCA, T-bars, knuckle / brake backing plate / lower ball joint / shocks. T-bars are not loaded. But I notice now that the adjuster arms that come off the pivot shaft are not symetrical. In other words, I'd have to screw one of the adjuster bolts in quite a bit to even make contact with one of the arms and start loading it.
I'm looking through the manual ('67 Dodge Monaco/Polara) and they make no mention of how to clock the front side of the T-bars into the LCA when installing them. The last step in the instructions is "slide t-bar into hex opening of LCA". That's it. No mention of where the adjuster arm should be pointing when you do that.
Am I getting this wrong, or is this an important consideration?
