Idle is fine. I have been wondering about a vacuum leak too.
I checked the cap when I replaced the wires - it's in good shape.Probably a good idea to change the distributor cap. If that wire was arcing, it may have messed up the cap terminal. You might have some carbon tracking inside the cap too.
Coil, Ballast Resistor, and ignition module/CPU are all new.Ignition breaking down under load is either a coil issue or leaking insulation/carbon tracking somewhere... Coil testing should be in the FSM and about 100 other threads... you would use an ohmmeter. Secondary insulation is easiest with a spray bottle of water and mist everything while looking and listening for arcing... if it doesn't work at idle, get a helper to hold the brake in gear and apply gas to load the engine...don't stand directly in front for this. you should see/hear the spark as the miss becomes obvious. Cap and rotor inspected or replaced as Big John said...
If all fails pull the plugs... at least you can read the spark plugs and hopefully find which cylinder(s) are the problem.
The car was running fine before I swapped the intake. I am thinking I did something there when I made that swap. My problem is... what?
my motor is running great now! I even hammered it coming around a corner, all four opened and it downshifted to first with a big hit. All right!
You ought to hear my story about the guy breaking into my garage. I went out there three times before my brain screamed at me, "Hey idiot - there's a guy in the garage!!!" He was in there all the while. D'oh! Some times I'm slow.
Serious? Ok....i want to hear the full story please ... sound hilarious and inquiring minds want to know
The dog kept barking. I went and did the same thing, finding my bake between the cars - THREE TIMES!! I even took the dog with me one time. My sister was saying, "I'm never coming back here."
We went on a trip to Disneyland the following week. The thief came back. I had left the screwdrivers in the door when we left; he yanked on my door until both broke. My neighbor found the door open one night and closed it. However, nothing was missing. To this day I can't figure that one out.
