Just my two cents Jon. You have the right idea about rebuilding due to the fact there may be more damage than you can see. Bent connecting rods and cracked pistons are possible. Hard to detect w/o a tear down. Word to the wise, don't go cheap on the rebuild. Bore the cylinders, new oil pump, new exhaust valves, cam and lifters. A good rebuild will wear out your car if maintained properly. Changing the transmission front pump seal and the rear tail shaft seal. Seals get hard w/ age. Replace scored rocker arms and rocker shafts. PM me if you have questions.
