Looking to rebuild 383
jake
wisconsin
I have a question, every time I look up a part for my 383 build, they ask me if it is a 383 from 68-71. I have one from 64. Could someone tell me the difference between the engines between those years? Thanks in advance.
The RB 383 should be earlier than 64 59-61 I think as long as you have 6 bolt valve covers, the only real difference would be the small 1.60 exhaust valves and if you are changing the cam you will need pushrods from a 68 up availible new less than $100. If by some chance you have four bolt valve covers which is not original there is alot different
No I have do not have the raised block. I do have the 6 bolts on the valve covers. So I am assuming that the internals are the same.
Maybe you have the "RB" 383 (as opposed to low deck) 383? I'm not sure what year(s) that were though.
