70bigblockdodge
There is the problem.federal pump
Not that I can tell. The pump internals were in great shape with no noticeable wear. It doesnt have vanes but rollers in this version. I'm betting on the bypass....will look into that when I have a chance.just wondered if it was cavitating under high rpms due to improper fluid or worn vanes.
What's wrong with federal pumps? I've heard the Saginaw was an upgrade but never a reason why.
As I understand it, the Saginaw is less likely to leak, has a better mounting bracket and has consistent pressure output.What's wrong with federal pumps? I've heard the Saginaw was an upgrade but never a reason why.
I really don't know what to advise. I half heartily looked into doing the conversion rather than fixing the leaky Federal on my car. A seal kit was cheaper and it was my plan to do this winter, but a cold garage and old bones... There are guys that swear by them, but I've never seen anyone that replaced a good Federal with a Saginaw. It's always "I replaced the leaky, whining Federal" so I can't say that they are really better.Well...I have looked and they are difficult to find. All out of stock like the brake boosters...but not Saginaw. Plentiful and cheap. I do not have the brackets for that or the pulley. Would it be better to source those from somewhere and buy the Saginaw or pay the higher price and get the federal (I have found them...just not cheap) I have no clue what the Saginaw parts would run me.
If you can be civil and just move forward on car issues then by all means explain your thoughts. There has to be a stopping point somewhere.
Are you referring to the control valve on the gear box? I have removed it and replaced the seals, but haven't gotten into the box itself. I suppose its possible something worked through and is blocking it.My theory is if your losing power assist under heavy load but not at curse or low power. I feel there's a piece of crud caught at the inlet valve of the box that when heavy pressure is induced, it forces that crud into and restricts your flow through the box causing hard steering.
Everything else you've done doesn't seem to be working, it's time to start looking/thinking outside the box for your problem. Then again I could be wrong, but I'm just trying to help. Good Luck
