superfragl
I have a rebuilt engine that has zero miles after rebuild and about 1 hour of run time.
The motor has 9.5 static compression, Lunati cam with following specs
I broke the cam in following manufacturer procedure. Ignition timing is set to 12* initial, 36* total mech. by 3000 RPM, with vacuum advance total timing is about 54*.
It idles fine, revs fine, has good oil pressure, starts right up but develops only 10 inches of vacuum at idle. When I rev the engine I can see the vacuum goes up to 25 or more.
Manufacturer says I should have at least 14 inches with this cam.
I did degree the cam during assembly, but I did one intake and one exhaust lobe only to verify cam timing.
So far I have checked following:
- Verified the gauge reading with another vacuum gauge.
- Checked the lifters by pulling the covers and making sure rocker arms are not loose.
- Tested brake booster for leaks and it holds vacuum at 10 inches (could not develop more vacuum with small hand pump for bleeding brakes), it did not make a difference with booster port plugged anyway.
- Tested distributor vacuum canister for leaks.
- Did and compression test and got all cylinders within 146 and 150 - engine cold.
- Checked the plugs and they look good - tan color - no black soot and not white (I think if there was an intake leak plugs would look white because of the lean mixture)
- Tried advancing the timing to 15*, 20* and that did not make any difference
- Tried adjusting carb. idle screws and throttle screws with no effect.
When I installed the intake I used standard steel gasket and silver colored sealer that came with it.
I have not looked for vacuum leaks yet, but how do I test?? If there is a leak under the intake - above the valley pan - how to check this?
Maybe I need to put some miles on this engine in order to see better vacuum readings?
Any other thoughts?
I would not bother with low vacuum, but I am concerned about power brakes being inefficient...
- Advertised Duration (Int/Exh): 268/276
- Duration @ .050 (Int/Exh): 226/234
- Gross Valve Lift (Int/Exh): .494/.513
- LSA/ICL: 110/106
Any other thoughts?
