charles messler
Hello everyone,
I have to change the strut rod bushings on the 68 fury and in the process of loosen the control arm shaft nut I discovered that the shaft is turning also. Should I use a vise grip to keep the shaft from turning while getting the nut off? I’m guessing I should replace the lower control arm bushing again too? Ugh!!
