Good points.....I wanted to take the easy way out first if possible, which would be like the lawn and garden cables that you can get some lube thru. May be more like a motorcycle cable with a solid sheath....cant tell yet. But, I moved the front end just a tat by pulling with vise grips.....so have to pull the wheel again to change to new one. At that time, I will be able to access the other end at the lever, and will get a bit more aggressive. May have to pull it and then some soaking and tugging will be in order. thanks
