Ok, problem not solved. Started her up, no issues. Put her in drive, issue reappeared (of course, this is all Ross's fault).
Anyhow, back to square one.
No DRL kit. Tried that (thanks). Here's what I did notice this morning. Since my ammeter doesn't work, I bought a plug in voltmeter from NAPA for short term use. When the door lights come on, it dies. No power, no read out, no nothing.weird one... You're not running a DRL kit on the car are you?
what about if you are sitting in the car not running but ignition on and then step on the brake pedal?
So, somewhere between the door lighting and cigarette lighter? And I looked up "backflow". However, it was written in an ancient Sumerian dialect, which Google could not translate...Backflow. There's a ground off somewhere.
yesI see. After my fusible link blew,...View attachment 387204
Thank you.Back to work!Possibly. Regardless, clean that up, check the pink wire for rub through underneath to the scorched connector.
I'd still look for a break, corroded ground, or a pinch/short somewhere too.
There is a hidden circuit breaker (single barrel fuse holder) as described above - mine was taped into the secondary harness for the console lights and was NOT marked on the wire diagram. This was definitely factory though, and caused me no end if grief (including wacky door light backfliw with the brake pedal) until I went nuts, ripped it out and took all the wrap off the harness and found it. Very odd.
I expect you have a lot of extra switched courtesy/map/reading lights, lighters, yadda yadda in your car. I expect all that may need to be looked at.
Great thought!....If only the borders were open....
I'm in agreement with Ross.
Step 1) Repair the known bad wire
Step 2) If no change.... ALWAYS go back to what was repaired/replaced last, before the problem existed.
Thank you, Devinism, for the tutorial. I will get back on it.Here is how all the courtesy, dome, map lights operate on MOST MoPars. I say MOST, well, because that's just the way it was. I've even seen the factory wiring diagram colors not jive with what is actually on the car, on 100% original cars.
Pink wires to each lamp are hot, all of the time.
Yellow wires from each lamp go to a ground source.
In the case of the dome lamp the ground wire feeds to each door "plunger" switch. Open the door and the switch completes the ground circuit. On the map light the button does the same thing. You may need to disconnect each one, one by one, to remove the switch from the circuit.
The headlight switch also has a dome system ground going through it (Brown, which also tees into your rear map switches, and also tees into Yellow wires). If you unplug the switch wiring that will remove it from the circuit.
I have chased these issues myself for HOURS before. Sometimes an accessory wire has been mistakenly spliced into a Brown or Yellow wire. Other times I found the wrong bulb type in one of the sockets.
I don't know why it wouldn't do it cold, other than you MAY have 2 wires almost touching, and as the wring warms and gets flexible they rub.
Happy hunting!
Happy hunting!
No, sir - checked that, and on cold start no issues. The plug in voltmeter will first start displaying crazy numbers, then quits. Then the door light come on. If I flip the map light switch, the map light comes on and the door lights dim. Flip the switch to off, and the map light goes out, but the door lights come up full. This all started when I blew the fusible link.
I sounds like a grounding issue at this point or as Ross suggests a back feed taking place thorugh your system.
I appreciate it. What keeps bugging me is that the only difference between before the instrument panel was removed and after it was reinstalled is that climate control cable that may have touched the back of the ammeter, because the fuse box damage appeared old, and the first thing I noticed upon reinstall was the ammeter was dead. The voltmeter is just a plug in type which I have removed for now.
Hoping that you find the issue. First thing if you haven't is to bypass that volt meter you installed and see what happens.
