Well a couple of weekends ago we ran up to inlaws house and grabbed the 3 383 he had.
Block #1
Original block to 65 fury III. Manual trans.Been sitting in basement for 40 years! Bored 30 over. Had box of new 30 over pistons on rods. looks like just a good cleaning and ready to go back together. now the problem is we don't have and can't find the main caps!! original head rusted from sitting in truck for 40 years. 2.08 intake 1.60 exhaust.
Block #2
"GTX block" is what i was told it came out of? Automatic trans.Pistons stuck Standard bore removed heads one head has one rusted off valve cylinder side. other head has two rusted off valves cylinder side. rest looks good if i can break pistons free and get to rotate. Heads have 2.08 intake and 1.74 exhaust.
Block #3
Unknown app? Automatic trans. Pistons stuck 40 over bore and decked. One cylinder a little rusty trying to get to rotate. Removed heads all looks good no rusted valves. same as block #2 2.08 intakes and 1.74 exhaust. This are the heads we will be using.
Now i'm sure blocks can be saved and used but I NEED MAIN CAPS FOR OURS??
How much are blocks #2 and #3 worth with no heads? and are the original heads and #2 block head worth selling both nee reworked. I also have 5 cast 4 barrel intakes and 1 2 barrel intake with carb. What are they worth? i need to sell parts to buy main caps and line bore. I don't want to use the other blocks we are using origial block!
Anyone need parts??
Block #1
Block #2
Block #3
Anyone need parts??
