twostick
Anyone have an LS6 Chevelle or L88 Vette laying around? I've got a 493 RB and 727 that needs a new home. Should have kept my Diesel Dodge 4x4. L88 would look cool rolling coal...
Kevin
Kevin
think oil pan vs cross member. @Stephan_oldtimerfun has a fury that someone had put a soviet diesel with m/t into so how hard could this be?Chevy/Mopar parts butt heads
A guy I follow here in upper MI on You Tube put a LS with a turbo in an A-body had to modify the K member and used a front sump pan. It can be done but it's not as easy as a GM swap.think oil pan vs cross member.
out of curiosity i looked in jegs to see if they had an oil pan that would clear the steering linkage. didn't see one, but maybe i missed it. dry sump maybe?you can order a box from Summit or Jeggs and install your LS whatever in no amount of time.
just looked at it. seeing it for the first time. can't say it won't work, but the steering linkage will be directly under the sump. hey, good luck, i hope it works for you.Looking at a batwing Corvette oil pan for this swap
