need 4 way window switch
CanCritter
alberta
need the 4 way window switch on drivers door....seems mine dosnt work...seen the rebuild kits...was wondering if anyones got a leed on any nos units...
thanx
thanx
Sure it's the switch? Did you test for continuity? I think the procedure is listed in the FSM.
got a call from Paul tonight...windows work great but switch was toast he was saying..will let him know in case he hasn't already
thanx
thanx
Would a 4 bank switch from a '66 have the same internals D? I have one of those apparently....
As both Critter and I found out...you can clean an old motor only so far as an old motor is an old motor. Got my passeger side all apart cleaned and put back together works ok but doesn't have the juice it needs to push the window up all the way
Welp looks like Bills on a roll tonight...Paul gave Bill a holler tonight to see if by chance he had a spare 4 way switch and apparently he dose and we can have...may be a NOS one to...woot....Thanx Bill tis greatly appreciated:thumbsup::thumbsup:...will settle up with ya at High River car show :O)
Thanx for the imput folks....a week to go.....
talking to Paul...says my windows are smooth and fast...cut yer head off fast...anyhow...been thinkin...do that on occasion...your motor
A.not much to wear out from what ive seen short of brushs mayby cant remember if there were bearings for the bottom of motor...thoughts?
...your brushs although 50% worn were well in the parameter to be functional...honestly when basics come into play believe motor may be fine...think problem may lie in lack of power to operate window power...possibly bad lead or ground...may be worth checking to see what kinda juice yer gittin...
only other thing is binding track but believe they should be fine after we cleaned them up...anyway food for thought.,.,.was buggin me
No problem! You've already donated a number of parts for my car, I'm just pleased to be able to reciprocate.
