GoneLoco99
I am the point in my build where I need to hook up the neutral safety switch/backup lights.
I bought the car without a motor or transmission. I have installed a motor & transmission and aftermarket shifter.
I am at the point where I need backup lights and getting the car to start with the key.
There is no neutral safety switch, currently on the car and I can not locate any wiring that goes down to that switch. The pervious owner may have cut it out, when removing original motor/transmission. Could someone please help me with this issue?
Need to know where the wiring for NSS/Backup Lights starts at and if there is a part or wiring system I can purchase to make this right and work correctly?
Pictures would be great.
Thank you.
Thank you.
